Outlook Memo Synchronization
1 replies · 2,203 views · Started 28 March 2005
Has anyone figured out how to transfer the memos from Outlook to the SX1? Using the Siemens synch program I can get the phonebook and to-do lists to transfer, but not the notes. Is there a third party program that will do this? How reliable is this program?
Better yet, my Outlook information is derived from my Palm Pilot, is there a program that will transfer the above information directly from the Palm Pilot to the SX1? My Palm Pilot does not have bluetooth.
Thank you.
SDS does not sync memo to Outlook.
I think your Palm Pilot should have Irda, right? Use infra-red to transfer calendar, to-do list and phonebook to SX1, but you have to do it one record by one record.
So, I recommend you to Hotsync the Palm Pilot first, and sync with SX1, then calendar, to-do list and phonebooks are transferred to SX1. The remaining memos can be transferred to SX1 via infra-red one by one.
As I can remember, you can transfer memos from Palm Pilot to SX1, but not vice versa. Try it yourself.
