how to restore quickoffice...
1 replies · 2,322 views · Started 29 March 2005
Hello, I've done a bad thing!
I have quickoffice (italian version) installed on my 6670 rs-mmc. I've tryed to install an english version of quickoffice because it seemed to me that mine didn't work (word didn't show open link....).
You can imagine what I've done: the new quickoffice did't work too so I disinstalled it!!! The problem is that the quickword, quicksheet and quickpoint links in the quickoffice folder are disappeared!!!! 😮 😮 😮 :frown: :frown: :frown:
I saw that quickword, quicksheet and quickpoint are still installed so I ask you if there is a way to relink the applications to make them works again!!!!
Please answare me...... :frown:
thank you 😊
Actually QuickWord at ur orignal rsmmc works. It will not search the word files for u in the mmc. U need to just on the word files from the filemanager then it will open it correctly
