Almost destroyed disk C:, now voice commands malfunc.
1 replies · 2,857 views · Started 30 March 2005
Hi guys,
I made a stupid thing by accident. While working in FExplorer, i clicked "C" while looking on disk C: and then approved the deletion. It started to wipe the disk and I immediately switched the phone off. After restart, almost all settings and contents were gone.
Since then when I try to record or execute any voice command / voice tag, it says "Voice System Error". *#7370# did'nt help.
Assuming C: is partly corrupt, I deleted files c:\system\Data\vcommandapp.dat, c:\system\Data\vcommandprofile.dat and c:\system\recogs\*. After restart, I still doesn't work, but those files are there again.
Any ideas?
Thanks,
Triplea, RH-51 / RH-67
Yes... make dupicate of contact with voicetag. delete orginal (contact) save new voice tag to new (copied contact).. and it works.
