I am looking for the code to format the phone (hard format)..
ne 1 can help me?
how to format the phone?
If it is a 3650, 3600, 3620 or 3660, then it is *#7370# (do it with a full battery or on AC & you will be asked your phone's lock code, which by default is 12345).
if i 4got my lock code how can i view it again? tnx
If you forgot your lock code, take or send your phone to the nearest Nokia authorized service center.
Hey everyone. Im new here :tongue: i have a nokia 7650 that won't even start because when i turn on the phone a blank screen with 'Nokia' appears then it stays there for a long time, after a while i get a 'memory full' message. I've heard a formatting is the solution but as i read here the only way to format a nokia 7650 is with a code that you insert inside the system... the problem is i cant even get inside the system... what should i do, is there anyway for me not to get the phone on a store and fix it myself? Thanks 😃
Cheers
No, there is no practical way for you to fix it yourself (unless you want to spend a lot of money on hardware equipment you won't need except this once + learning how to use the hardware + finding illegally distributed copies of firmware flash files + with no guarantee that it is enough to fix the problem in the first place).
In other words, the answer is for you, too: take or send your phone to the nearest Nokia authorized service center.
