The 'Phone' task is critical to call operation and must not be disabled.
When the A1000 is restarted, the memory size of the 'Phone' task is about 1MB. After a full day use with >30 voice calls, the memory size increased to ~7MB!
Is it normal? Any solution other than rebooting the A1000?
I have toubles like you on my a925. And phone programm be very slow after 10 calls 😞
Weekend wrote:I have toubles like you on my a925. And phone programm be very slow after 10 calls 😞
10!??? how do you deal with it? firmware upgrade?
I notice this as well, but ever since i flashed it with the generic firm, I dont see this problem anymore... so you might want to try and reflash it...
boobood wrote:I notice this as well, but ever since i flashed it with the generic firm, I dont see this problem anymore... so you might want to try and reflash it...
guess what? i got my a1k from 3 Hong Kong. they say no new firmware for us while Motorola HK has the new firmware but a1k from 3 HK are not eligible for upgrade. i just can't accept it!!!
can i go back to original firmware if there is ever a backup programme before i go the generic route?
That is thery strange, because i'm use original software version 30.80.20 😞
