MMS and 100k
4 replies · 2,450 views · Started 01 April 2005
1. Is it possible to send wider mms's than 100k.
2. Is there somekind of application that could stop video for 100k incase of needed?
tomato wrote:1. Is it possible to send wider mms's than 100k.
1. Depends on ur Service Provider .. how much do they allow you to send .. here in the United Arab Emirates its 60K per MMS Limit.
2. I guess programs like camcorder .. give u recording limit for the video .. u mite wana try that out.
There are operators that allow 300KB MMS messages, or larger. What your operator's maximum is, you have to ask them. The "MMS Conformance" specification (somewhere on http://www.openmobilealliance.org) define - as the name says - conformance criteria regarding MMS messages that device makers and operators have agreed to.
My ISP allows only 100k, but I'll try to ask them to increase it.
And thanks for replying, I'll also try them out (apps)
