Problems with webviewer
6 replies · 1,836 views · Started 30 October 2002
I don�t know what kind of connection I�ll setup for webviewer 1.6. I first got the error message "kernel..." and the solution for that is to remove the ipgateway to 0000000. After that I don�t get an error message but I can�t get it work anyway. Do I have to change any more settings? I guess my connection is for wap, that could be the problem.
Yes, I can understand that, but I don�t know which settings which are bound to wap. "Access point name", should this be changed? Should I enter any primary name server and secondary name server?
[quote="Raveot"]Yes, I can understand that, but I don�t know which settings which are bound to wap. "Access point name", should this be changed? Should I enter any primary name server and secondary name server?[/quote]
Yes, you must make a new access point, which uses GSM-data, HSCSD or GPRS. You cant use wap access point with webviewer.
And you should enter name servers, you can (usually) get those from your
service provider.
Hope that helps some.
Hi all,
So far,the settings U need is to know the dial-up no. from ur service provider. Then set the gateway to 0.0.0.0. Usually this works. BTW,
webviewer does not support proxy servers. 😉
