Hey,
When you send your pictures via MMS, the 6630 automatically resizes them to be more mobile friendly. Is there any way we can change the size, or make sure it sends it only as the original size??
Cheers,
M.
Hey,
Cheers,
M.
Messaging > Options > Settings > Multimedia > Image size & MMS creation mode
Note that operators place restrictions on MMS size & that the MMSC may also do reformatting/compressing of the images going through it.
If you want to be absolutely sure the image is sent in original size and format, send them as email attachments.
The MMS size on uk networks baring 3 is 100k
The majority of photos taken with the 6630 are well over this hence why it has to compress and resize to fit.
