i have the new Nokia SU-8W bluetooth keyboard for my Nokia 7710!
my problem:
no driver available at the MMC-Card for the Nokia 7710
my question:
someone has a solution for me ?
thanks
Fidibus
my problem:
my question:
thanks
Fidibus
Try nokia support pages
http://www.nokia.com/nokia/0,6771,69342,00.html
Otherwise find your local Nokia Service Centre good luck
Coming very soon, just be patient.
what other keyboards are compatiable with
the 7710
mort10 wrote:what other keyboards are compatiable with
the 7710
Freedom Keyboard... $99 US. It has 5 rows of keys instead of Nokia's SU-8W which only has 4. Freedom Input just released drivers for the 7710.
http://www.freedominput.com/Freedomkeyboard/index.htm is their site URL.
know when it will be released in India,
or will I have to import it.
I have a Microsoft bluetooth keybord for my PC... Can I connect it with the 7710?!?
No, not unless the keyboard has its own drivers for the phone, or is fully compatible with the drivers for some other keyboard. For both options, I suspect the answer is the same: No.
N/A wrote:No, not unless the keyboard has its own drivers for the phone, or is fully compatible with the drivers for some other keyboard. For both options, I suspect the answer is the same: No.
Thanks for the quick reply!!!!
Do you have any suggestion what bluetooth keyboard should I buy?!? 😊
The Nokia SU-8W works, so in that sense it is a better option than one that doesn't. 😉
N/A wrote:The Nokia SU-8W works, so in that sense it is a better option than one that doesn't. 😉But I believe the point is that the Nokia keyboard does not work, unless I am missing something here.
I've had random people claim to me that it works with the 7710, but none of them have been able to show me the actual drivers.
I just finished our review of the 7710 and stated in it that the 7710 doesn't work with Nokia's keyboard. I'd love for somebody to show me wrong, as would a lot of other people I imagine.
Best I can tell, the 7710 supports the DUN profile, and the OBEX file transfer and object profiles, but nothing else.
It does work & there is a driver: http://www.my-symbian.com/forum/viewtopic.php?t=20846&postdays=0&postorder=asc&start=0
N/A wrote:It does work & there is a driver: http://www.my-symbian.com/forum/viewtopic.php?t=20846&postdays=0&postorder=asc&start=0Well, there does appear to be a driver that is linked to from that thread, but nobody has found a link from Nokia itself. And while the .FI site seems to list the 7710, the English site doesn't list the 7710 as being supported.
In any event, I will get them to send me one of the keyboards and give it a shot. I called the Freedom folks earlier today and they are going to send one of their keyboards over, too.
MFO wrote:Well, there does appear to be a driver that is linked to from that thread, but nobody has found a link from Nokia itself. And while the .FI site seems to list the 7710, the English site doesn't list the 7710 as being supported.In any event, I will get them to send me one of the keyboards and give it a shot. I called the Freedom folks earlier today and they are going to send one of their keyboards over, too.
Freedom keyboard is awesome compatible with nearly everything, even has a microsoft driver so you can use it with your PC.😎
MFO wrote:Best I can tell, the 7710 supports the DUN profile, and the OBEX file transfer and object profiles, but nothing else.
Teardrop wrote:Freedom keyboard is awesome compatible with nearly everything, even has a microsoft driver so you can use it with your PC.
