Can we Update the Memory of Nokia 7650
1 replies · 2,841 views · Started 01 April 2005
This is a kinda Problem i'm facin. i downloaded few softwares from Nokia site. Not it says it doesnot have enough memory to function those features. Is there any possible way that the Memory of the Handset is Increased, by a added card or by Increasing memor??? Please help me out in this. Thanks in advance
If the additional amount of memory needed is small, stop all other running programs and perhaps also in addition use an app like Space Doubler: http://my-symbian.com/7650/applications/applications.php?fldAuto=194&faq=2
If it is storage memory you need then you can uninstall exiting apps, delete pictures, messages, contacts, etc.
But you can't increase the actual amount of memory in the 7650.
If you need more built-in memory and a memory card slot where you can add even more, then the only solution is a new phone.
