Hi All
On my P900 I installed Tracker 4. I used a couple of skins for a while then bought a new combo pack. Each skin hides (well it is not obvious) the option in Tracker to import a new skin.
I have now imported a skin called Ellegance which REALLY has hidden the tracker option for skins.
Is there ANYBODY out there who knows where this is? Failing that who or where the supplier is (bought it as a combo pack from handango).
many thanks if you can help
george
:icon4: My dear friend.. you are the first one i tell this to but there is a program i created that simulate windows 98 on your UIQ phone... when you start the program windows 98 will show up and you can browse open and edit anything!!! it is not complete yett but will be out on my site www.adsa.1go.dk. the program is called OperativeShell.sis and works best on a925/a1000 but might work on p900/p800... any way you will need the mobileVB booster.. i have a trial version on my site so dont worry... the thing is that the entire program is developed on a trial version of mobileVB so you will only be able to use it for 2 days... you simply backup the time to 8 agust and run the program.... screenshots and how to install i found in the download section of www.adsa.1go.dk. :icon4:
