I just couple of days ago bought new TEC 512mb MMC card. The card works fine and I installed some emulators, games and apps on it. Now when I play with emulator or any N-Gage -game it plays normally for awhile but after a certain amount of time it almost freezes and the game runs very slowly for about 5-10 seconds. I've tried *#7370# and *#7780# and I've formatted my MMC 2 times without any results. I had the same problem also with my earlier 128mb MMC card but then the problem solved with just formatting once my MMC and installing all stuff again...
N-Gage QD gmes/emulator lagging!
Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Mystery` wrote:I just couple of days ago bought new TEC 512mb MMC card. The card works fine and I installed some emulators, games and apps on it. Now when I play with emulator or any N-Gage -game it plays normally for awhile but after a certain amount of time it almost freezes and the game runs very slowly for about 5-10 seconds. I've tried *#7370# and *#7780# and I've formatted my MMC 2 times without any results. I had the same problem also with my earlier 128mb MMC card but then the problem solved with just formatting once my MMC and installing all stuff again...
Upgrade your software to 4.03 then will not freeze take it to the nearest nokia shop takes 1 hour reformate you mmc so that it's compatible with new software Georja
Georja wrote:Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)Upgrade your software to 4.03 then will not freeze take it to the nearest nokia shop takes 1 hour reformate you mmc so that it's compatible with new software Georja
I have already this firmware:
V 4.10
09-09-2004
RH-29
