smart movie setting help me!!
14 replies · 15,558 views · Started 03 April 2005
hello....guys..i using my phone with a 512 mmc card....6260 n 7610
but the problem is how can i convert a movie clip and send it into my phone?
i hv tried with the smart movie conveter... but the problem is...i dono how 2 set the setting... and when i try.....the file conveted come out with 300+++mb
that's the problem...my memory is only 512...i only can put one movie clip that not longer then 4 minutes? some one pls help me.... and can some one teach me where to get great app for nokia s60 phones?
wylun wrote:hello....guys..i using my phone with a 512 mmc card....6260 n 7610
Use smartmovie convertor. Use either the normal xvid or 3ivx codec. Set the bitrate according to how much space you want. For xvid your space will be estimated so keep an eye on that. You can also select start and end points to save space. I hope i got your question.
hello.
I need the settings for the smart movie player version 2.12 for the nokia 6630..
can you help me?
I must admit m8, i always rip my movie etc, with dvd dycrpter, then i use nero to convert it into VCD, after that i bung in to smart movie convertor and the end result is amazing, and a really small file size to, the sound is crisp and the picture is sharp, i watch a lot of things like frasier, comedy shows on my phone, and my Nokia 6630 is amazing with smart movie, i dont know about the rest of you guys but i find Real player on this phone a load of crap, even with real low quality settings it's still jerky, smart movie is the best thing since "nokia phones" 😃
Erm..
I'm not really professional in this field, juz a high school student but i'm quite interested about mobile phones.
About the smart movie, i think your com needs some kind of codec to make it works.
Besides, it's important to change the setting when ur using the app in pc such as the frequency, etc.
Higher frequency provides better quality movie but i dun think that mobile phone needs such good quality as its screen is not that big.
In fact, u can change it to lower frequency.
That's juz my little knowledge about it.
Hope it will help u.
AlexC wrote:I must admit m8, i always rip my movie etc, with dvd dycrpter, then i use nero to convert it into VCD, after that i bung in to smart movie convertor and the end result is amazing, and a really small file size to, the sound is crisp and the picture is sharp, i watch a lot of things like frasier, comedy shows on my phone, and my Nokia 6630 is amazing with smart movie, i dont know about the rest of you guys but i find Real player on this phone a load of crap, even with real low quality settings it's still jerky, smart movie is the best thing since "nokia phones" 😃
hi alex, other than smart movie, is there anymore programs out there playing movies?
hi all, recently a frd of mine bought a 512 Mb dual voltage flash card, as i can see it, the card haf one single row of contact n additional contact above it, well ..
when i try to insert the card to his hp, i realised tat the contact on the 3230 hp memory card was available only for single row contact(single voltage)card instead of dual voltage,
jus like to clarify if the dual voltage card is able to supply dual voltage as stated... 😊
Dual-voltage cards can have only only 7 contacts like single-voltage cards. When there are more contacts, it is a high-speed card; more parallel bits can be transferred in a high-speed compatible device.
ufo wrote:hi alex, other than smart movie, is there anymore programs out there playing movies?
I think there is an application called PVplayer
5thdimension wrote:I think there is an application called PVplayer
erm..is it realiable? better than smart movie? i haf try to download it in my frd N6230i, it doesnt work, any advice? where can i get PV player?😊
ufo wrote:erm..is it realiable? better than smart movie? i haf try to download it in my frd N6230i, it doesnt work, any advice? where can i get PV player?😊
Well, i dun think that Pvplayer is better than smart movie but i juz recommend it to u since that u ask for it.
Besides, 6230i is not a series 60 phone, so it can't install PVplayer(.sis file).
5thdimension wrote:Well, i dun think that Pvplayer is better than smart movie but i juz recommend it to u since that u ask for it.
is there anyway to watch movie on 6230i ? mayb other format??
ufo wrote:is there anyway to watch movie on 6230i ? mayb other format??
Sorry, i can't help in this because i'm not using 6230i.
I'm afraid that i say something wrongly.
Maybe u can try to search for other forums or ask for others to help.
5thdimension wrote:Sorry, i can't help in this because i'm not using 6230i.
it is ok, am glad u guys replied to me 😊 many thks
