quickword for 6630
12 replies · 2,777 views · Started 03 April 2005
My 6630 is from 3.dk, and the software is modified by 3 as I can see their logo. Quickword doesn't work on my 6630, whenever I fire up quickword, it tells me "no data". both quicksheet and quickpoint work well (but their versions are both 2.0 ), and quickword's version is 1.3. I downloaded quickoffice from nokia.com but still i get quickword at 1.3 and doesn't work.
help??
johnsletter wrote:My 6630 is from 3.dk, and the software is modified by 3 as I can see their logo. Quickword doesn't work on my 6630, whenever I fire up quickword, it tells me "no data". both quicksheet and quickpoint work well (but their versions are both 2.0 ), and quickword's version is 1.3. I downloaded quickoffice from nokia.com but still i get quickword at 1.3 and doesn't work.
help??
the latest one Nokia have is on the 6680 support website. There's other stuff too like an official Adobe Reader and other stuff.
Didn't you even try finding it yoursel? It is not very hard to find even if you just go to http://www.nokia.com/ first select the relatively obvious "Phones" and then by now the even more obvious "6630" and then "Support and Software for Owners" (which is kind-of obvious, too, if you're looking for software for the phone).
Also a more direct way to info about a specific model:
http://www.nokia.com/phones/6630 >
But that's no good....becouse u can't edit the word files...or even create one....I have a Ximpda cr*ck of 2.0 version but it doesn't work on my 6630......
but the original and the last one.... demo from the official site is working at least...but u can't use it for a long time.... 😡
qucikword from nokia site doesn't work on my 6630 while quciksheet and quickpoint work seamlessly. I checked the versions for each, both sheet and point are 2.0 but word only 1.3. am I the only one? could you use quickword? what version is it?
if you want to edit you have to use the pay version. There's a trial but for 30 days.
The issue sounds odd. Check support on quickoffice website?
johnsletter wrote:done that. quickoffice by nokia at the 6639 site doesn't work. tried quickoffce at 6680 site and all 3 works!
good to know.
:icon14:
Will the 6680 software on that page such as the PDF reader and Quickoffice work with the Nokia 3230?
Cheers
Luko
luko wrote:Will the 6680 software on that page such as the PDF reader and Quickoffice work with the Nokia 3230?
Cheers
Luko
you can give it a try.
They work fine on my 6630.
U know I wanna edit word files.... so all we need is version full and cracked and working good on 6630)
