Well they are meant to be out today in the US. Any got one early and tried it out on an a1000?? Anyone know for sure that they work?
Cheers
Fil
Cheers
Fil
filny wrote:Any got one early and tried it out on an a1000??lNot quite what you'd call early but it's working here with Motorola Desktop Suite seeing the full capacity of the card. I do get occasional hangs during the transfer of files from the PC to the phone though (although the connection, either bluetooth or USB, remains intact). If you have a memory card writer that you can fit the transflash card into (within its SD card adapter) and use a direct connection to write files to the card, that may be a way around this problem if you get it. I'm sending the handset back for a firmware update as the current version is only 51.14.15 and I want to rule this out as a cause of the problem.
