<<<<WARNING .... newbie 1st post ahead !!!!>>>>
I'm using my brand new 9300 Communicator to access my corporate webmail. I can access the fairly fat Outlook webmail OK, but the (very) much thinner Outlook PDA webmail will not render on the 9300's native browser. To minimise telco costs, I'd rather access the PDA webmail as you can imagine.
As a 1st resolution attempt, I'd like to try an alternative browser. Do any exist?
Assistance much appreciated
You could try Webviewer, a Java based browser that uses a proxy to scrunch out a lot of un needed data. A review of it running under Series 60 can be found at http://www.allaboutsymbian.com/reviews/review2.php?id=52
Ewan wrote:You could try Webviewer, a Java based browser that uses a proxy to scrunch out a lot of un needed data. A review of it running under Series 60 can be found at http://www.allaboutsymbian.com/reviews/review2.php?id=52
Thanks for the tip, which I tried out. It worked on some sites, though not on my PDA webmail. Work's webmail involves a number of (IMO unnecessary) window pops which seem to have confused the devil out of Webviewer.
Perhaps I should talk to my employers or even to Nokia. Maybe it would be easiest just to change jobs!!! 🙄
Try this - [http://www.skweezer.net/
QUOTE=jemacdonald]Thanks for the tip, which I tried out. It worked on some sites, though not on my PDA webmail. Work's webmail involves a number of (IMO unnecessary) window pops which seem to have confused the devil out of Webviewer.
Perhaps I should talk to my employers or even to Nokia. Maybe it would be easiest just to change jobs!!! 🙄[/QUOTE]
