Remote S60 at www.mobileways.de does'nt work on N6630.Anyone know a prog for webcam enhancing.And e-mail attachement does'nt work when browsing mail.yahoo.com , is there any patch .sis to correct this?
Go on Developpers!! :icon1:
parismus wrote:Remote S60 at www.mobileways.de does'nt work on N6630.Anyone know a prog for webcam enhancing.And e-mail attachement does'nt work when browsing mail.yahoo.com , is there any patch .sis to correct this?Go on Developpers!! :icon1:
really, i'll be greatful to you, if u please tell the procedure in detail to work remote 60 with n6630......
yes, that would be nice!
how do you do that ? :icon2:
it's easy just download remotes60 and install it
then configure the com ports in the winapp and click start.
then in the symapp on your phone press option-->bluetooth--->other
and select the pc
MY REMOTE S is NOT CONNECTING TO MY PC.WHen i startup rem s60 on my phone it just shows me the IMEI number and a pic and the ONLY option is EXIT!!!please help
you downloaded the cracked version you have to download the trial version
