Calander Synchronisation Problems
3 replies · 2,242 views · Started 05 April 2005
Hi Guy's
I have recently bought a Nokia 6670 phone.
I am having problems with synching my outlook calander with my phone, when i try to synch I get an error message:
'failed to open outlook, the specified folder could not be accessed: mailbox- calander'
I am running XP Professionl service pack 2, with Microsoft office professioanl 2003 & Outlook 2003.
Can you please point me in the right direction on how to synch these two together.
Many thanks.
Mark
Make sure you have the latest PC Suite from http://www.nokia.com/pcsuite
Then check the sync configuration, or recreate the config from scratch (launch PC Sync, hit "Properties", then "Create new configuration", etc. Make sure it is using the correct Outlook profile and folders, if they are not default for Outlook.
Thanks for that, I am just downloading the latest version of PC Suite now, will give it a try.. thanks again.. 😊
N/A wrote:Make sure you have the latest PC Suite from http://www.nokia.com/pcsuite
That has worked a treat many thanks
markfull wrote:Thanks for that, I am just downloading the latest version of PC Suite now, will give it a try.. thanks again.. 😊
