Is there a Bible SW - version NIV for the 9500 communicator? I have been checking the different web sites and so far no success.
Bible Software
There is eBible version 1.00. U can find that on Symbianware.com
bosoris wrote:There is eBible version 1.00. U can find that on Symbianware.com
I believe it is not NIV.
There are very many bible programs for the 9500/9300; you can get from simple bibles to study bibles with lots of resources. Check out the following sites:
a) http://www.christiancdrom.com
b) http://www.handango.com and go to the "education & Reference section, then religion sub-section.
c) you can always go on e-bay.com and find the bible section.
I got a rather exhaustive bible study library (program) made by packard tech. thru e-bay. You will love it. 😃
peteding wrote:Is there a Bible SW - version NIV for the 9500 communicator? I have been checking the different web sites and so far no success.
You should have a look at the Mobipocket website (www.mobipocket.com). You can find several versions of the Bible, but also many other ebook titles.
thank u
