I have a big problem.
The application I was running before on the phone, doesn't run now.
I upload it without problems, but when I try to run it a small screen called:
"Program closed" appears with the following message:
Program (program name)
Reason code KERN_EXEC
Reason number 3
And I only can press "Continue" in that small window and comming back again
to the screen where you choose the application you want to run.
Does anybody know the reason of this problem and how to solve it?.
Thank you for your attention.
Atreo.
a little more info would help...
what application is it? where did you install it (c,d,x)
Hi!.
Thank you for your answer.
I upload "BTExample" from UIQ SDK (it's in folder QExBluetooth).
I've uploaded it three times. The first one just to see how is working by Bluetooth between a pc and a mobile with Bluetooth ans Symbian (A925). The second time, I modified it, and uploaded it without problems. I also run it without any problem.
As I didn't achieve my purpose (showing a message) I decide upload the unmodified code of this example, the same as first time.
After that, it doesn't work in the mobile giving that error explained in my last message.
I don't understand why it doesn't work now and before it did, and there is free memory, it was uninstalled correctly and so on.
I hope with this it'll be enough.
Thank you for your help.
:icon14:
