Application to change background, oplogo and such
5 replies · 3,149 views · Started 31 October 2002
Which should I have? For example, all my backgroundpics just take a little bit of the screen now, I want them to stretch out.
For oplogo SeleQ, because it almost "automatically" does it.
But for background pictures you just have to make sure the pictures are
174x132, then it fills whole bottom part of screen.
Or buy Active Desk then you can have full screen backgrounds, but
I didn't like the program.
Ok thanks! But I can�t get I can�t stretch the pics to the sides. Maybe that�s not possible.
Hmm really strange. Doesn�t work here. Could you paste a screenshot from your phone here so I can see how it can look? The pictures leaves white areas on the sides.
[quote="Raveot"] The pictures leaves white areas on the sides.[/quote]
Yeah, the pic leave white areas (1 pixel by side), I think you cant make what you say.
For example, look at the indicators of signal and battery, you�ll see that there are both white areas on the sides, this is normal, you can not fill all the screen, I think...
Anyway I think that 176x133 is the best size to set the pic as a background... I tried it with lower and higher sizes, but I didn�t like them...
