firmware upgrade for 6630??
3 replies · 3,075 views · Started 06 April 2005
is there a way i can upgrade my firmware for nokia 6630 myself?
is there a service center in the USA??? is there a reliable center?
pachi wrote:is there a way i can upgrade my firmware for nokia 6630 myself?
no it has to be done at a nokia service centre. find one at www.nokia.com
well put it like this, to flash it urself u would need a flashing box approx �500 a cable about �25 and the files which would have to be obtained llegaly
so seeing as ur 6630 is probably under warrantee, its free anyway. otherwise its approx �30.
But yes of course it is POSSIBLE (if it wasnt then the SC wouldnbt be able to do it either!)
Chris
