reset nokia 3660 phone
5 replies · 3,612 views · Started 06 April 2005
My N3660 phone is not starting due to some buggy software that i installed. I have been going through the posts on these forums and other sites to learn that hard reset can take it to factory default data losing all the data. I'm fine with that except none of the measures listed are working for me!!!
i have tried with abc(edit) key down and power on option.
i have tried Send + 3 + * option and power on option.
These are not letting me in, in safe mode.. Is there any other way of booting in safe mode for N3660?
How can I reset my phone?
~dapi
Is the problem started after u were trying to install .gdr files? If that is so then u might be one the most unluckiest person, because the remedy for that is yet to be found, apart from changing the corrupted internal memory
das_vicky wrote:Is the problem started after u were trying to install .gdr files? If that is so then u might be one the most unluckiest person, because the remedy for that is yet to be found, apart from changing the corrupted internal memory
No, it was .sis file!
try to mremove your mmc then boot in safe mode while powering ur phone up hold the pencil key.when the boot up is successful pres *#7370#
das_vicky wrote:But if the phone dosent boot after using pencil key in nokia 3660?
Maybe your phone is damaged, first power off your phone then remove the memorycard, then power it up while powering hold down the pencil key until it is completely on standby mode/completly turn on. then in standby mode press *#7370# to reset phone.
