splash screen
2 replies · 2,397 views · Started 07 April 2005
how do u change the splash screen (the one that says NOKIA in the beginning after u switch on ur phone) i found it in Z:\Aystem\Program\ the name of the .exe is splashscreen.exe when u open it it shows NOKIA logo like the one when u switch on ur phone..the ques is..how do it change it?or can i change it wif sumthing?i know C# builder can do tahat but i donno whether the phone allow to change it..
The file is in ROM (Read-Only Memory) and you can't change it. If you don't like it, you can just keep your phone always turned on and you won't be bothered by it. And when you do need turn the phone off and back on again, you don't have to look at the display when it boots, either. 😉
