Nokia 6670 vocal commands
2 replies · 1,454 views · Started 08 April 2005
Hello,
I have a problem with voice command on my nokia 6670.
When I record a vocal command (es bluetooth) and I try to call it back very often it doesn't recognize it!!! 😡 😡 (I've seen that if I call it back immediately after I've registered it it's ok, if I call it back after a few time it does not work!!!)
I think it does not depend from my voice because I remember that on my old 6210 it works great!!!(even with my radio on at loud volume!) so I don't know!?
I've also noticed that when I try to change a vocal name at my contacts it give me an 'error on vocal system' 😮 ; I've to delete the old one and then record new one!!! 😡
Is that normal or it is a problem of my telephone?
I've the latest firmware version:v4.0437.4ch 15-9-04 RH-67
I was thinking in a my phone problem but it is the second identic phone I bought that have this problem (the first one I've changed)
It seamed to me that at beginning it worked better (when I bougth the second phone vocal commands seemed ok) and it started to have problems after I've installed some programs (citymaps, tube, slovoed, pdf+, skyforce). it seemed to me very very strange.....what do you think?
Often I use it with Motorola HS810 bluetooth auricolar (that worked very well with my old nokia 6210!!!) and I noticed that when it repeat the vocal command (the very few times it works!) I lose the first part of it!
I precise that the recognising problem is either with or without the auricolar....!
Please write me something!!!
I'm going mad!!! 😡 😡 😡
thank you
Does anybody have tried this phone?
Can you tell me if your telephone works well (vocal callings, I mean) after some software installs?
Please, tell me something..... :redface:
Bye
Hi, never had these problems, with or without hd3w headset. Either commands and vocal names.
But i have to say that I found it really sensible at record time. So try to record in an env without noise.
Bye
