Speed Dialling does not work after upgrade to 3.62
1 replies · 3,048 views · Started 28 December 2001
Hello,
this is my first post and it starts straight with a problem User posted image.
I finally got my 9210 upgraded to 3.62 and everything works fine, except speed dialling User posted image.
I activated it again from the phone menu and started to fill the empty places. The phone did not recognise the previous speed dials (I don't know where they were saved). Whatever number I used now, the pop-window either showed me "not found" or "in use" (I presume that the contacts that I'd like to use have to be in the contacts directory on the phone = C drive data\contacts.cdb.). I deleted "phone.ini", but it did not help.
Any idea how to correct this small issue?
Thanks!
Regards from cold and snowy Finland,
Tilman
Great, some finnish User posted image
Seems that your contacts is in use and speed dial app cant open it...weird....
You allready did restart and new try?
Regards
JeP
