Hi guys! I was just wondering if it would be possible to convert normal videos dowloaded from the net to .nim?? if its possible how do i do it step by step? I have some videos that i want to put on my communicator for viewing, but the file format is different, thanks!
video conversion
use the Nokia Multimedia converter.
Check also the topics on 9210 multimdia regarding nims problems from 4u2nv.
You will find a link to Dazler site wich is a great tutorial.
http://nokia.warlocks.be/NokiaNimSettings.htm
Good luck
where can i find this program?--multimedia converter..tnx
What is your RAE Version?
Check this also:
http://www.nokia.com/phones/productsupport/9210/downloads.html
cheers
