Sending FAX with 9210 - Problems...
0 replies · 2,506 views · Started 31 October 2002
Hi all,
i just upgraded my mobile subscription in order to have the ability to send and receive faxes. My problem is that i often have a message on the outbox wich says that the fax was not sent and the status is FAILED. The strange thing is that in such cases if i check the number called with a fixed phone i can hear the tipical sound of a fax machine and i don't understand why the 9210 seems unaware of that.
Anyone has problems in sending faxes?
Thank you.
Ivan.
