Cause it doesn�t seem to play my 80 k signal.
How large can the midis for ringsignals?
Size of the file has nothing to do with it. I have one in excess of 100k and that plays fine. I would suggest it's something to do with the midi file. If you can post it up on the forum, I'd be happy to test it for you. 8)
Ok, here it comes!
Hmm, now it seems to work here!
Problem solved then 😉
