Hi all Nokia 6600 lovers
I am having problem transfering any midi file from my N-6600 to anyother device using bluetooth or infrared. When i select the file and use command to send via bluetooth or via infrared nothing happens. On the other hand it can send wav, amr, 3gp but not midi.
Any idea Y.
Second thing is there any software to send any type of file over blue tooth.
Regards.
file transfer problem.
as far as i know the phone dosen't send .mid or.sis files over bluetooth or infrared so one thing that you can do is using any explorer (fExplorer or seleq etc.) rename the file having any extension other than .mid and you will be able to send it and again rename it to.mid once you have received it on the other device ! 😃
Job Well Done.
Thanks.
Mad_dog wrote:as far as i know the phone dosen't send .mid or.sis files over bluetooth or infrared so one thing that you can do is using any explorer (fExplorer or seleq etc.) rename the file having any extension other than .mid and you will be able to send it and again rename it to.mid once you have received it on the other device ! 😃
job well done
Another solution is to use ProfiExplorer (that comes with ProfiMail) from http://www.lonelycatgames.com/
