* * * * * * * WARNING ABOUT VIBBY v.0.7 * * * * * * *
0 replies · 1,614 views · Started 11 April 2005
* * * * * * * WARNING ABOUT VIBBY v0.7 * * * * * * *
about Vibby.v0.7.1 released 10 april 2005:
IF YOU INSTALL VIBBY v0.7 ON A MOTOROLA A925, DO *NOT* SELECT AUTOSTART !!!
SOME PEOPLE HAVE "KILLED" THEIR PHONES !!!
it�s the "usual" problem with any app that doesn�t start OK, and therefore stops the phone from booting.
DO *NOT* USE AUTOSTART, IF YOU HAVE A PROGRAM ON C: !
it seems to be a lot of problems vith vibby v0.7, chrashes and conflicts with other apps...
however, if you want to auto start vibby or any other program, if you have nopEx and SMan there is a safer way to do it:
1. in SMan, change the hardware-profile to autostart in D:
2. select autostart "others"
3. select vibby to autostart with enough delay, (50-60s?), so your phone can boot BEFORE vibby starts
4. copy C:/system/recogs/SManRecog.mdl to X:/system/recogs/SManRecog.mdl
then if you have a problem, remove your memorycard and start your phone without any "autostarting" programs.
i tested vibby that way, and it starts fine.
but using vibby caused a lot of crashes with netfront and SMan, i ended up re-installing both Netfront and SMan.
i�m not sure that all problems were caused by vibby, since i haven�t tried SMan�s autostart function before, but vibby is a strong suspect...
/bw
