Autostarting Apps, A925
1 replies · 2,030 views · Started 11 April 2005
if you want to autostart a program when the phone starts, do NOT select autostart in the programs settings !
it�s the "usual" problem with any app that doesn�t start OK, and therefore stops the phone from booting.
DO *NOT* USE AUTOSTART, IF YOU HAVE A PROGRAM ON C: !
however, if you want to autostart a program, if you have nopEx and SMan there is a safer way to do it:
1. in SMan, change the hardware-profile to autostart in D:
2. select autostart "others"
3. under "others", select the program to autostart, with enough delay, (50-60s?), so your phone can boot BEFORE the program starts
4. copy C:/system/recogs/SManRecog.mdl to X:/system/recogs/SManRecog.mdl
then if you have a problem, remove your memorycard and start your phone without any "autostarting" programs.
/bw
