Hi all,
are there any free apps out there for converting movies to play on a 6600/6620?
I tried smartmovie and it works very well!
Any free apps that can do the same thing?
I'm new, but cant seem to find a sticky on converting movies... :frown:
I just got this phone and am loving the possibilities...all i need is a 1G card.. :tongue:
BTW, great site! :icon14:
the best program for converting video downloads for your 6600 is real helix producer plus 9 , the only problem is its not free , the quality of the converted file is superb but you will need to go to hack site to get this program and in result you are at high risk of getting trojans , this is what i had to do so be it on your own head. 😮
nokia multimedia converter is a good one.lets you select the sound and video quality as well
you also can use Quicktime pro to convert movie to 3gp. and you can also convert from 3gp to avi, mov or mpeg. if you want to burn to cd your video that is taken by your phone.
