Turning off operator logos
2 replies · 2,970 views · Started 11 April 2005
Off? Not really, as far as I know, but you can set an operator logo that matches the background colour (e.g., an all-white rectangle). The effect is the same.
The operator logo resides in c:\system\apps\phone\oplogo and easiest way to set them is to install FExplorer (http://www.gosymbian.com/) and use it to set it.
If there are no logo files, then the operator name is looked up from a table and it is displayed.
Almost everythig is possible 😃
Chk this out:
Op logo - All about...
Hope this helps
Cheers 😉
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
