Changing Operator
1 replies · 1,556 views · Started 12 April 2005
all pros out there do anuone of u know wats the opreator logo code for starhub or is there a list for all the operator codr as i am using 6670 i know can change the ops logo but i need to chage the file to the ops code... pls help... thx
If you use FExplorer (http://www.gosymbian.com/) to set the operator logo, it will do all the work for you automagically (assuming you have a "starhub" SIM card in the phone).
If you only need the operator country and network code, you can also just have FExplorer show it (Options > Phone > Network info).
