Anyone else miss calls waiting cause they can't hear beep?
9 replies · 2,996 views · Started 31 October 2002
Hi all,
I have missed loads of calls because the beep is soo faint you don't notice half the time, especially outdoors, just wondering if anyone else had this problem? Is there any way to make the beep louder?
Regards,
Eoghan.
[quote="Anonymous"]Hi all,
Regards,
Eoghan.[/quote]
Hmm, i don't encounter such problems. 😉
That is a normal problem for me. It is known by all of my friend that they need to be patient.
yeh i get that, the beep isn't obvious enough, I often mistake it for background noise on the other end or line noise.
Same problem. It sucks. In fact i've never heard any beeps when other calls come in. Only once or twice i've actually heard the faint beep it makes when text messages arrive.
Yes I have this problem very often, I hope something can be done about this... time to put on my programming hat and chew some cashews 😉
[quote="talk2sk"]Yes I have this problem very often, I hope something can be done about this... time to put on my programming hat and chew some cashews 😉[/quote]
I will buy you the cashews if you can fix it 😉
Eoghan.
[quote="Anonymous"]
Eoghan.[/quote]
I think you owe talk2sk some cashews 😃 😉
