how to move sms for 6680?
4 replies · 1,894 views · Started 12 April 2005
i have a 6680 and can i know how to move the sms i have saved in the phone memory to the mmc .. ?
thanks.
It is - surprise, surprise! - actually documented in the phone's User's Guide (with a lot of other useful details that you might need to know, so you should read it).
It is also a good idea to familiarize yourself with the excellent search facility that this site provides (with it you can find existing discussions and answers to questions you don't then have to repeat): http://www.allaboutsymbian.com/forum/search.php?
Hint: Messaging > Options > Settings > Other > Memory in use
i know that the message settings can be changed to save in memory card ...
but wat about those that i have already moved in the phone , i dun know how to move it to the memory card.
When you do the setting change, the messages are moved (or at least should be moved).
hey cool, i knew how to change it on my 3650, but on my sisters 3230 there is no option to do so, how can i make sure the inbox is on the memory card? im soo glad that the 6680 has the option, hey queen where did u get ur 6680 and if u can plz tell me the price if that is ok with u because i really want to buy one asap 😃
