I want to load pics from my digital camera Sony t3 directly (not via computer) to my 9300 using a USB connection. What do I have to do? Do I need to install a t3 driver to my 9300 (the driver is for mac and Ms)? Do I need other programs as well in order for the driver to work in 9300. Is their another way? Hj�lp!
Panu
How do you think to make that possible?? The 9300 doesn't have USB-host. So unless the Sony uses MMC (which I know it won't, it uses memory stick (duo)) I think you can forget it. Not possible
I use one of those USB card readears --there are 6 in 1 and even 8 in 1 types that can handle 6 or 8 different cards-- and transfer the images between the two cards.
So in your case you need one that has both a memorystick slot and an MMS slot. Connect the USB reader to the computer via USB and insert both cards into it, the cards will open as drives on your PC (or Mac) and you can transfer pictures from and to them.
Here's one from Lexar:
http://www.lexar.com/readers/multi.html
I hope this helps. Good luck...
But you'd still need a PC for that, and for what I understand, he doesn't want that...
Delta737 wrote:But you'd still need a PC for that, and for what I understand, he doesn't want that...
Oh, no PC! That's a tricky one. Sorry I missed that. I'd echo Delta's reply then, and say forget it 😞
