6630 on Orange
2 replies · 1,950 views · Started 12 April 2005
Hi, a friend just got a 6630 on orange and he is having trouble sending files via bluetooth. he tried to send a wav file to his old phone and got some message about the format, i can send wav files etc ok but mine was bought sim free, do orange restrict you in anyway with regards to files your able to send?
thx
cliveuk wrote:Hi, a friend just got a 6630 on orange and he is having trouble sending files via bluetooth. he tried to send a wav file to his old phone and got some message about the format, i can send wav files etc ok but mine was bought sim free, do orange restrict you in anyway with regards to files your able to send?
thx
Its a firmware restriction. Just use FEexplorer to rename the wav extension to wav_ or something.
ie:
myfavringtone.wav
to
myfavringtone.wav_
You should now be able to send. Alternatively just use Profiexplorer (part of profimail)
DK
