moto a925 wont start?? Help Plzzz
5 replies · 3,997 views · Started 13 April 2005
hi
I installed magic themes this morning but after i applied one of the themes the handset switched off and won't switch on now
Its stuck with the initial dark Motorola 3G background screen with a note saying
Program closed
Reason KERN-EXEC
Reason nukmber 3
and option saying continue
But when i press continue
it just keep on trying to start but wont get started
The Magic themes are for P900/800 but did get installed with no problems
Any help appreciated
Isohi
I recently bought a motorola A1000 and i try to install some of the p900 software into my motorola a1000 (as i know the OS in P900 is same as A1000) and when i start using the software or even after the software is install...the phone suddenly restard and get stuck in the start up screen (Motorola 3G)...can u pls help me??? pls...
my fone notive board:
PROGRAM STARTUP
REASON CODE KERN-EXEC
REASON NUMBER 3
It's handyday 2004, installing it causes this problem.i nkow this is a eror reason. If you know the way to repair this eror please help me ..... thank u so much
my email: [email][email protected][/email]
hi
Program closed
Reason KERN-EXEC
Reason nukmber 3
Thanks Hamid
hi
Program closed
Reason KERN-EXEC
Reason nukmber 3
Thanks Hamid My E-mail is [email][email protected][/email]
hamidpf wrote:hi
Program closed
Reason KERN-EXEC
Reason nukmber 3
DO AT YOUR OWN RISK!
Hi there (note this is only for you with the a92x) i can se one solution for you guys and that is to reflash your devices (note that you will lose all data on c: and all settings will disappear including the gprs, mms settings and such). To do this you will need pst wich you can find here
http://mobilforum.lokalen.org/downloads/Flashverktyg/PST_6.7_GENERAL.zip
and the patch
http://mobilforum.lokalen.org/downloads/Flashverktyg/PST_6.7_Patch.zip
and you will need the so called flash (the program wich will reset the device download all four parts)
http://mobilforum.lokalen.org/downloads/Firmware/Firmware_A925_30.80.20/
You will also need patience, one usb cable and one phone charger!
Now your ready to begin and good luck!
1. First unpack PST GENERAL and install it on the computer
2. Unpack the PST PATCH into the directory where PST is located
3. Unpack the 4 flash files remember (when you unpack them remember to change the end of the name of the directory to 1 for part 1 2 for part 2 etc.) This also on the computer.
4. Now its time to flash the phone pick out the battery, sim card and the memory card out of your a92x.
5. Connect the charger into the side of the usb cable (there is a hole there).
6. Make sure the usb cable is connected to the computer and the charger in a working socket.
7.Hold down the two game buttons on top of your a92x and insert the usb cable with the charger in it the screen will light up.
8. The computer will prompt "blank a920" or something like that in the bottom of windows a window will pop up select to install rutines on your own look in the folder where you installed PST and install the rutines from there.
9.Click on start in windows/all programs and PST open flash and test commands the a92x will appear at the bottom of the program.
10. Browse to open the first part flash click on the mobile device in the bottom of the program and then flash.
11. there will pop up more windows who install rutines let them do that automatically.
12. Now you may experience som problems (only do these rhings if you do get problems) (like flash failed and so on), take it easy it's nothing to worry about. If you do PST will stop and maybe ask "flash another device?" select no. Take out the usb and do the hold game buttons procedure again and try to flash again.
13. If this did go as it should have the flash program now will prompt "flash another device?" select no and disconnect the usb from the phone and do the button procedure again. The a92x will appear in the bottom of the program again. Select browse again and flash with the second part. Do this untill you have flashed with all four parts then you are ready to start the phone.
14. If this don't work properly just do this whole procedure again. I've never experienced that my phone would'nt start again.
i installed magic themes i got the same prob its call botloop mines got 2 the shop 2 get fixed costing me �10
