images and pictures in mail message
3 replies · 1,741 views · Started 13 April 2005
I notice that the images are not displayed in a mail message. It just shows a square box with the word image. Anyone can help?
regards
In 'Account settings' - 'Advanced' - 'Default e-mail type' did you select 'Formatted text (HTML)'? And also, are you sure you downloaded the entire message and didn't brake off the connection?
Raven wrote:In 'Account settings' - 'Advanced' - 'Default e-mail type' did you select 'Formatted text (HTML)'? And also, are you sure you downloaded the entire message and didn't brake off the connection?
Done it. Will try the click on image....
