dark screen on 7650
6 replies · 2,553 views · Started 31 October 2002
It seems that my screen is darker on my 7650. Its not the contrast. The white colur isnt really white its more like light yellow. I am interested how it seems on other 7650 and can i fix this somehow?
[quote="ARMac"]It seems that my screen is darker on my 7650. Its not the contrast. The white colur isnt really white its more like light yellow. I am interested how it seems on other 7650 and can i fix this somehow?[/quote]
Sometimes under diff. lighting i see my light like yellowish.. But under the correct lighting, its white for me.
yes as far as i know there r 2 types of the screen colour for the 7650
one is the White
the other one is yellowish white
but if u try to take a screenshot of the white colour both these phones
they will result the same white on the computer, so it's just the screen of the phone that result the yellowish colour
Yes right on some light conditions its really white on some yellowish. so everything is fine then right?
And how did you mean 2 types of screen? 2 series of 7650 with different screens?
thanks guys
I think that must be then from two different types of backlight leds.
could be repairable in NSC, but i think it will cost a lot. ??
[quote="ARMac"]Yes right on some light conditions its really white on some yellowish. so everything is fine then right?
thanks guys[/quote]
yes that's right there are 2 types of screen out there
i already compared mine with my freind
also for the keypad LED mine is white with a bit of pink colour as for my friend is white with a bit of yellow
