does anyone know where i can get my nokia 6630 unlocked thorugh codes. (dont like the direct method sicne it destroyed my 7250I & my 7600!!!)
nokia 6630 unlocking
currently the only easy method is to contact your network, cough up the �� and they will hopefully get Nokia to issue you a code in the next few months.
DK
As far as unlocking the 6630 goes guys and girls is.....
I contacted nokia and said I have a t-mobile locked phone that i bought from ebay and I want to unlock it and guess what they said. Sorry but you will have to contact the network, as they are the ones that locked the phone up and there the ones that can unlock it. Nokia supplies the networks with phones that are unlocked sim free stock.
steff2632 wrote:does anyone know where i can get my nokia 6630 unlocked thorugh codes. (dont like the direct method sicne it destroyed my 7250I & my 7600!!!)
You get the unlocking code here http://www.mobileunlocksolutions.com/ .
This is the unlocking site & helps you to unlock your mobile easily..
Hello, Just read out your mail, having no problem with the unlocking nokia mobile.
Also you dont hesitate like that, i will give you a special way to unlock your mobile as safer side. just get this site http://www.superunlockcodes.com/ And you dont feel this may spoil your mobile, juct follow the codes with your mobile. they will clear your problem@ low Costs.
