is there a program for the 6630 that is like a mobile version of MS Paint?
i know that the sony ericsson k500 comes with one built in...
also, are there any music making programs available? or ringtone composers?
There's a basic free program on the Nokia website if you havent already got it installed. Its called photo editor.
there is also two other programs for editing pictures, photorite and photoart. with photorite you can add various frames on your photos, and photoart can change your pictures like they�are painted in a couple of different styles (impresionism, cubism etc.). tried it on my 6630, they both are great!
i want a program so i can actually draw pictures on the phone...
maybe the lack of an 8 way joystick makes this impossible.
No, it is not impossibile. You can draw pictures using an Etch A Sketch even if it goes up/down and left/right. 😉 http://www.etch-a-sketch.com/html/onlineetch.htm
Mr Peach wrote:i want a program so i can actually draw pictures on the phone...
Its an 8 way joystick.
No, it is not. If you remove the front cover and the keymat, you will see only 4 contacts + the center under the directional pad.
up and left, up and right etc work because both contacts are depressed together
yes there is a software for painting. it call Painterstudio 1.0. i had try it in my 6600. but its to slow on my phone
