Nokia 6600 bluetooth problems
6 replies · 3,123 views · Started 14 April 2005
Hi there i've just got a Nokia 6600 and it's GR8 -BUT- i don't understand the Bluetooth when i want to connect to my phone it goes ok but thn wen u look @ the PC suite it sayz no phones connected 😮 so PLEASE help and give me info ! ! 😉 😕 :dontknow:
50 viewers already but no replies
Can som1 plz put a reply evan if u think it's not gonna help much it just might help me
http://www.allaboutsymbian.com/forum/search.php
Search tip: search for *BOTH* the words "Bluetooth" and "6600".
Bluetooth connectivity issues is probably among one of the most frequently discussed topics on this forum, so the answers and instructions, troubleshooting tips, etc., are already here many times over. All you need to do is to spend a couple of minutes finding them.
hi there buddy. hey i just registered to this forum. but i am having the same trouuble as u are having. but tell u what, sometimes when i restart the mobile the bluetooth is detected. so try it.
Dude,
This is a error with PcSuite. You can try using the Billington Bluetooth Adaptor and its software else try using the software provided by ur bluetooth adapter company.
