there are any software to the Nokia 6600, like the active standby program that comes on the 6630 and 6680?
Thanks a lot
Taita
Thanks a lot
Taita
Not quite, but there are things like Active Desk, which you should find in the shop: http://www.allaboutsymbian.com/shop/
N/A wrote:Not quite, but there are things like Active Desk, which you should find in the shop: http://www.allaboutsymbian.com/shop/
Quite like the look of this but the original poster said that active standby is available on the 6630 and 6680? I have the 6630 and can't find it anywhere.....any idea if its available ?
Cheers
That's not right; it is only a feature of the 6680, so far, as far as I can tell.
