SmartMovie OGM encoding problem
0 replies · 1,945 views · Started 15 April 2005
I'm testing this software and found out that the converter has some problem with the OGM files. The sound is messed up, you can hear some sort of strange loud noise, also the voices are weird. Basically, you can't hear anything. I haven't had problems with normal AVI files though. Is this a known issue?
