I have 9300, while synchronizing calendar from my Pc windows XP SP2 outlook 2003 appointments time are shifted back by 1 hour. I'm using PC suite 6.5.
Anybody knows how to fix that?
I don't know the specific answer to this but it strikes me that it could be 'daylight saving time' not being set on one side (the phone probably). Worth checking I would think.
walidn wrote:I have 9300, while synchronizing calendar from my Pc windows XP SP2 outlook 2003 appointments time are shifted back by 1 hour. I'm using PC suite 6.5.Anybody knows how to fix that?
I had the same problem, I have changed the summer time saving, but it did not helped, then in the clock application when switching to word clock I realized that the the time zone for Budapest was GMT+2 while it should be GMT +1. You can change this setting in the Edit/City data (or something similar as I have it in Hungarian.)
May be there are ather cities with wrong timezone too.
Laco
Same problem here. I just set the time zone in Windows to Greenwich +0 adn reset the time again. Seems to solve the problem.
I had the same problem.
It occured already when I transfered data from my previous Communicator (9210).
I finally found that the problem was that I added my own city in the world clock and probarbly didn�t pinpoint the location on the map of time-zones correctly or something.
I live in Sweden and wanted to add a smaller town than Stockholm, the capitol of Sweden. So when I changed it back to Stockholm (which is one of the default towns in the list) the problem was solved.
Fix is quite simple. This occurs simply because you have unchecked the "Automatically adjust clock for daylight saving changes".
more info can be found in crazzycool.blogspot.com/2009/01/outlook-2003-how-to-fix-incorrect-sent.html
Wicky
