NEED HELP IN Symbian OS for 6630
3 replies · 1,698 views · Started 16 April 2005
I have recently purchased Nokia 6630 and got hit by virus. Dont understand the OS . Which anti-virus prog to install?. How to find which virus has infected me.?. Have installed virus protecton program. How can I disinfect/scan my mobile. How to see which prog is running, how to see the C drive etc etc. You can see that I dont know anything about this OS. Anywhere I can read to navigate/operate thru this OS. all help will be greatly appreciated. i am desperate.
Moe
Go to following link... Download the F-Secure Mobile AntiVirus, transfer it to your phone using Data Cable which comes with it. Install it and scan it for viruses.
http://mobile.f-secure.com/downloads.html
I would say, first try those virus removal tools which r provided on the same above page. Bcuz most common viruses are Caribe, Skulls .. I hope, you know how to intall applications on ur phone.. If not, Go thru user guide which comes with 6630.. its not difficult to do it.. best of luck!!
P.S. : And next time keep ur bluetooth off or in invisible mode to avoid viruses spread via bt. Don't accept any files from stranger via bluetooth
Thankx. Thats what I did. In addition to this i went to C drive and deleted all the virus related files. Dont know how to reboot my phone though. Any ideas?.
I dont want to to do a soft reset.
