hello. i just changed over the housing on my 6260 from silver to black and have 2 problems.
1) when the phone is open it occansionally comes up with a message telling me im about to remove the memory card.....pretty hard to do that when the back cover is on.
but when i put my old cover on it is fine
2) my other probelem is this. When up flip the phone open, normally you hear 2 clicks....now i have no clicks. I have opened the phone and looked at it from ever angle and i cant fingure our where the clicks come from..
I hope this all makes sense and i hope someone can help me
regards
DAve
Hi
I wanted to do this, can you let me know where you got the casing from? and was it easy to do?
Ian
nig6 wrote:HiI wanted to do this, can you let me know where you got the casing from? and was it easy to do?
Ian
hello
i bought the casing on ebay for anout $29 aussie dollars. I followed the instructions that someone posted on this site but it was still hard to do. It looks easy if you follow but it just takes time to do. Worth doing if ur casing is worn and strached.
Make sure you buy a T6 screw driver so you can open the phone
😮 I got a fascia on Ebay a nice red one (have a thing about red Fascias). However I have not discovered how to take the original off and after your concerns about the clicks and things am I mad to want red instead of silver. can someone please put the instructions here again as I am a new member to this and also to forums.
Thanks Tracey
metalroses wrote:hello. i just changed over the housing on my 6260 from silver to black and have 2 problems.1) when the phone is open it occansionally comes up with a message telling me im about to remove the memory card.....pretty hard to do that when the back cover is on.
There is a sensor when you remove the back cover it is located on the bottom left corner of the phone beside the card slot . When you put in the cover it pushes down the sensor. So check if your new cover has a plastic protusion on it.
traceylill wrote:😮 I got a fascia on Ebay a nice red one (have a thing about red Fascias). However I have not discovered how to take the original off and after your concerns about the clicks and things am I mad to want red instead of silver. can someone please put the instructions here again as I am a new member to this and also to forums. Thanks Tracey
http://www.uselessinfo.pwp.blueyonder.co.uk/dismantle6260.htm
mine has no click whatsoever
